Hi
I have a civic 1.8 from 2006 and the radio/ac display doesn't show any digits, it just has the backlight. At the beginning, when I turned on the car, the display was dark without any digits but I switched from radio to CD player and the display showed all the information without problems until I turned off the car, but now changing it no longer wakes up the display.
Did the display die or is the radio having problems? What can I do to fix this problem?
Font Gadget Cloud Auto part Display device
Thank you all and sorry for my english
search YT to find the videos on this,
worst case it needs a new unit, best case you can get it out and re-solder the pins.
Discussion Starter · #5 ·
Hi
Isn't this solution for when the display only shows some digits or part of them? Is it also a solution for when it is completely turned off?
It seems that the display does not receive any information.
Is there any way to check if the display gets information to show?
