1 - 1 of 1 Posts
i need help with the radio antenna wire... how and where does it go from the radio unit to the back side of the car... is it a one single and solid cable all the way through or not ? i have recently installed by myself new speakers, amp and everything works OK, but radio signal is bad! i have lost more then а half of the stations....
does anybody have a picture or diagram for where it is and how it goes through the car ?
so far i tried to realign + cable for the amp that goes through the car. now it runs far away from everything ))) grounding a radio unit, grounding antenna box at the glass window. no change at all.
there is another thing.. if i open a trunk door fully, then radio reception works better, less garbage & +4 stations more ))) but that's not a solution.
1 - 1 of 1 Posts
