I was using my parrot system for a call when the Radio, Parrot and Central console went out. Once I stopped I also noticed the remote central locking had gone as well!
I checked on the forums and replace fuse 16 under the bonnet but it just blows straight away. Before I take it into the garage any idea what it could be?
Its a 2006 2.2 diesel SE with 157k on the clock.
Gareth
How is your Parrot wired into the car, via the option connector perhaps?
Disconnect the Parrot and re-load fuse#16.
I am not sure how its connected but I'll have a look and let you know. Are you thinking its the parrot system that is having a problem as I as was using that when it went?
It's a good place to start ain't it.
Unplug anything that isn't OEM and investigate from there.
