I recently tried to fit a new stereo in my 2008 mk8 but the unit didn't work and so refitted the factory headunit. However now the dashboard display/clock is no longer working or the radio itself. Also the central locking isn't working too.
Firstly I disconnected and reconnected the battery. Then tried the key reprogramming method, nothing.
I thought the fuses for those areas (25 & 35 internally) may have blown but when I've replaced them both the problem is still present.
Does anyone have any ideas what I may have done and what I can do to fix them?
Anyone know whether any other fuses are likely to be at fault for the door locks and the radio/display not working? Going to have another look at all the fuses internally and externally today
I've found a helpful video on youtube showing the same problem as myself -
going to try replacing Ext Fuse 16 today and let you know in case anyone else is a dumbass like myself and has done the same. :)
