1 - 17 of 17 Posts
I have seen a post like this before with no solution.My radio display is showing everything on, then fades out again,then on then off.Is it a big problem or somthing small:confused::confused: PLEASE HELP:(
Did you find any fix to this rare fault?
Mine has done almost exactly the same for quite some time now, getting worse and worse, switching between normal and 'bleeding' mode (where all the hidden background info lit up) more and more frequently. I can't tell you how annoying it is! :(
I hope it is caused by a dodgy connection somewhere, but I suspect there is no cure to this problem other than to replace the whole radio/temp. unit...:mad: ...and I don't think that will be cheap!
Ps; my car is the sat-nav version, so it is the smaller version display unit besides the sat-nav screen.
I think time has come to pay a visit at the local Honda dealership!
....... I think time has come to pay a visit at the local Honda dealership!
Try asking in this and the Wanted sections - I just got a replacement CD player for €50 …
Reactions: amronno
Thanks for that! :)
I could always do that, of course, but I think it is much easier to get hold of a replacement HU than this info display.
Anyone know the parts number of this radio display?
Thanks for that! :) I could always do that, of course, but I think it is much easier to get hold of a replacement HU than this info display. Anyone know the parts number of this radio display?
A whole new HU is serious money ! ...
But, in any case, like the CD player, I think the radio \ info display unit is a separate module ? ...
Part no. - no idea ...
So, what you are saying is the CD player you bought from another member on here is a separate part of the HU? Didn't know that, I thought if the CD player broken-down you had to replace the whole unit. Sorry for the confusion! My bad! :)
Yes, the radio display is a separate module, and I also think it is an easy job to replace it, meaning you don't have to dismantle a lot of trim/panels on the dashboard to get access to it...hopefully! :)
Also having this issue..it is temperamental though, only occurs sometimes but when it does, it stays for that day. Pain in the arse!
Sounds like I have the same issue. The CD/Climate Control/Clock display will either be blank, hang or show a corrupted mess of LCD segments.
The car has been back to the dealer 4 times over the last 6 months. Three times the connections have been checked and it's been ok for a while. Last Tuesday the whole unit was replaced (£360 part), and the problem came back again yesterday.
About to ring Honda, but any suggestions more than welcome.
An easy thing you can try, probably wont work but worth a try.
Disconnect the battery, go have a cup of tea or whatever and put the negative back on.
Seems to resolve any things I get.
Would it fix a hole in the exhaust by any chance?
Disconnect the battery, go have a cup of tea or whatever and put the negative back on..
Good idea, but I'm hoping for a permanent fix.
My dealer has had the car back and investigated. It's not the display unit, or the cabling, so apparently it must be the stereo unit. Everything displayed on the screen is driven by the stereo.
I was having some problems with mine earlier in the year but thankfully seems to be ok at the minute. I got quoted at £848.99 from Honda (exc VAT and fitting) for a replacement HU
ok im trying to get behind the screen but cant remove it My screen doest this thing but i know that the connector behind it is doing these problems just cant get to it to fix it. Anyone know how to remove it?
1 - 17 of 17 Posts
