1 - 12 of 12 Posts
As the title states. When i push the startbutton, the radio and clock flicks off, and sometimes they don't always click on again after the car has been started. They can get power again after one minute or after ten minutes of driving. Sometimes the problem is not there for a whole week before starting again.
Since there is a clicking noise that seems to turn theese things on and off, my guess is that they share a relay that's connected to head unit, clock and ciglighter? But I can't for the life of me find where in the fusebox it is located. Tried finding it using the fn2workshop site, but could not find it. The car is a 08 Fn2.
Sent from my SM-G973F using Tapatalk
Discussion Starter #2
Anyone have any ideas as to what I can be? Ia there a relay or could it be a fuse about to go out?
Moderator
Sounds like a relay. Fuses do not get into the state of "about to go out". They either blow or work OK. I have never heard of an intermittent fuse (other than solid state fuses that reset when the excess current is removed)
Yeah it has to be a relay. Have no idea though as to what relay controls radio/clock and cig. lighter.
Bump. Anyone have a clue what relay is causing the sig lighter, head unit and radio/temp screen to turn on and off?
It's random when it happens, and it's clearly a click coming from under the steering wheel to the left when it happens. Kevin
Been looking over the fn2 workshop manual to see if I could find any mention of the relay, but no luck. From what I have gathered the relay is not located on the interior fuse box, but rather some where under the steering wheel/in the dash. Seems strange that I cant find any info about this relay anywhere.
I'm guessing I'll just have to get in the dash and start digging to find the relay.
I am at a complete loss here. What could I be missing? I can't find the relay I am looking for, if that's even the problem.
What could prevent those three things to not get power after the car has been started?
After a long time researching I have reached the conclusion that it must be the Acc cut relay that needs replacing. I finally found another user with the same symptoms as me, and really hope this solves it.
It's deep in the dash so will post an update when I locate it and if it solves the problem.
Hello kevven
I have the same problem, i was sure that it was the acc cut relay a few months ago but my problem is that I can't find it, how did you do it? Did you have to disassemble something? I find it almost impossible to access without disassembling anything
Thanks!!
As I seem to have forgotten to update this post. It was the acc cut relay. The link above shows how to fix it with pictures and info about the replacement part :)
Discussion Starter #12
Hello kevven
Thanks!!
Sorry. Forgot to quote you in my reply. See the info above:)
1 - 12 of 12 Posts
