Hey all,
My first question on here as it's a Honda so should be verry little trouble.
Anyway, my radio reception is perfect until as soon as you put on the heated rear window, then it just becomes interferance until the window heater is switched off again.
Any ideas????
Cheers.
Reactions: s5gsa
I was told by a dealer my heating element was damaged in the window and not covered by warranty, hence no fix for me other than a complete new tailgate glass.
I don't believe that now, given you're also suffering this problem!
I need to investigate the Wiki...
It's def a problem in the rear window as when i disconnect it and plug in an external arial......problem solved!
New rear window needed.
I had this problem from new , went to dealers & they checked it out . Found to be defective rear screen which they replaced under warranty without any grief.
Bugger ... I have the same issue.
Reading the wiki it says dodgy grounding along the cable up to the head unit is thae cause ... but no suggestions as to where to check for the joins/grounds ... any ideas/suggestions?
