Anyone knows how to unzip the passenger seat from the back? I can't find the end to pull as it seems to be tucked away where I can't reach
This is to find the source of a very annoying rattle every time I hit the slightest bump [smilie=hate.gif]
My seat had a rattle to, how ever I found that it was a little loose on the fixing, the rear up right, what I done was put black electricians tape around the catch when folded down, sorted it right out. I dunno if this is the same rattle your getting but could be worth a try, :/
Thanks for the suggestion, but my problem is coming from the front passenger seat right under the headrest area.. I can even make it rattle by knocking it gently on the side.
The end of the zip is tucked up inside the seat. If you put your finger up inside the seat following the zip you can feel the end. Pull that out and unzip. Then poke it back up when done! Rattle free passenger seat is lovely!
