1 - 9 of 9 Posts
Hey guys,
Is anyone here using RDX injectors??
If so, did you delete the cold start idle valve? I heard RDX don run with it.
i have this mod with ID 725cc bud heard that this is good mod for all aftermaket (larger then stock) injectors even OEM RDX
Thanks Marcin.
I'm running rdx injectors brm, what's this you are talking about?
Hi mate,
Look at the picture, are you running your set-up like OEM or like the pic?
Colins assist valve is in place.
RDXs run fine with this in place, TBH I've read stock injectors run fine with it removed too
@Colin
It's designed to raise the idle slightly to assist in warming the engine, its a valve on the water housing on the RHS of the RRC mani, and it shuts at about 120F , it vents air past the injectors off the intake :)
1 - 9 of 9 Posts
