I run a decat just now with tdi north 3" exhaust and tegiwa exhaust manifold! If i get a cat refitted is it going to effect my map?! : /
Batmobiles Rule ✌
if your current map is for no cat then the answer is yes if you want to run for long periods with it fitted. If you just want it in for mot time then you will be ok. It will judder like mad around 3500-4000rpm as it struggles to force air through the exhaust past the cat without mapping.
Ok! Yea i think tdi north supply a bolt in section! Its for long periods so gonna have to bite the bullet!
Anyone know a friendly Mot place as mine is de cat and will fail the emissions test... Around the midlands or London..
