1 - 2 of 2 Posts
Hi
can you guys have a look at the rear side of my rear brake discs and tell me if the quite wide coarse lip is causing a really bad grating noise when i'm driving.
Looks to me i could do with replacing the discs completely?
and if so how do i get those hard to turn retaining screws off?
Discs don't look to bad to me. You sure it's not the metal tab on the top of the brake pad? If so that the wear limit tab which means the pads need doing. As for the screws if there to tight to get with a normal screw driver you need a impact driver that you whack with a hammer
1 - 2 of 2 Posts
