Hi :grin2:
I've had my '07 FK2 for about a month now, and I'm really happy with it.
The other evening I noticed that the rear dome light doesn't turn on when I unlock the car / open the door like the dome light in the front does.
The light is in the middle position (positions: ON / MIDDLE / OFF). If I switch it to ON position and then to MIDDLE position, lock the car and unlock it again, the rear dome light automatically switches on, but then it only works until next time I'm using the car.
Any suggestions? :confused:
MY22 Jazz EX Hybrid
Only works once, bizzare.
Is that all doors.
Reactions: kha90
Discussion Starter · #3 ·
Just went out to do some more testing when I noticed that the light was flickering a bit. Took out the bulb an replaced it and so far it works... Will try to check again in an hour or two. If it works by then I guess it was just a bad connection :laugh2:
MY22 Jazz EX Hybrid
I changed mine to a blue LED bulb.
Reactions: kha90
Discussion Starter · #6 ·
Just checked again, and it seems to work fine now.
I will probably replace them for LED too :smile3:
Thanks!
Re: Led
Word of advice don't go for a ultra bright LED, because its a nuisance at night as it is blinding when you get in the car haha, good luck.
