Has this happened to you? Have your rear doors every filled up with water?
My rear doors on my 2006 Honda Civic seem to fill with water. Looks like it is coming in from behind the door handles, also seem to happen more on the nearside door.
I've figured out how to drain the water out using the rubber plugs at the bottom of the door, which at least stops the sloshing noise, but don't want water getting in at all.
Anyone else experience this? Do I just need to get Honda to replace the rubber seals behind the handles?
There has been a few threads on this subject. Some folks have removed the plastic drain plugs to prevent a build-up of water.
There's a thread to read here:
http://www.civinfo.com/forum/bugs-faults-irritations/4335-drainage-holes-doors.html
....and another here:
http://www.civinfo.com/forum/bugs-faults-irritations/1401-water-leaking-via-windows-into-doors.html
.....and another here:
http://www.civinfo.com/forum/bugs-faults-irritations/5624-door-full-water.html
PS...as a matter of interest I always check the little flaps on the door drains, after washing my car, to make sure they are resting on the outside of the drain, rather than being stuck on the inside. It may help your problem if you snip off a mm or two from the bottom part of the little flap.
Talking of rubber drain plugs in the bottoms of the doors...my 06 Civic had them but in my new 08 Civic they have not been put in. Seems like Honda have dispensed with that idea.
Reactions: marc1
