1 - 2 of 2 Posts
When the rear seats are upright and latched into place they rattle against the metal loop. Ive tried using double sided foam and also relatively thick duck tape, taped around the metal loop. But the problem is that when you push the seat back it seems to take a chunk out of the tape and so a small patch of metal is still exposed and thus still causes a rattle.
What is the best stuff for wrapping around the metal loop, I figure that if you wrap too many layers the seat will not clip properly.
I had a rattle from the metal hoop but it was coming from where it was bolted to the body. Had to take off interior panel to fix!
1 - 2 of 2 Posts
