hi, these are my current readings for the back of my ctr fn2:
(L) 0 05 (R) 0 00 toe
rear camber sits at (L) -1 25 (R) -1 36.
do i need any adjustments?
if so how much will it cost for just the shims with postage included please.
thanks
cj
thanks
cj
The toe readings, is that toe in , or toe out?
The camber is very good, but you would try and aim for toe in each side around 0.05.
Rich
ok, that's great, thanks CJ. There really isn't much wrong with that printout with regards to the rear.
I would probably recommend one shim to alter the toe on the drivers rear, to bring it to toe in like the passenger side. The only problem would be, the smallest toe shim is 1mm which would change the readings on the side from 0.00 to 0.08. This is a little more than the other side, but would be better overall as both sides would be toeing in.
I hope this makes sense. If you want to order the mentioned shim, give me a call today and i will get it posted out.
Rich
