I've read the rear speakers are 165mm, but tried some kenwood and they are to wide to fit through the hole gap. The underside of the speakers catch..what speakers are fitted to your fd2's? Is the holes in the shelf cut out or spacers fitted to make them fit? Or what make is fitted to any of yours.
Sent from my SM-G920F using Tapatalk
Can't help I'm afraid but I'll watch this thread as I really need to sort the ice out on my fd2! May just drop it off with an ice specialist and get them to sort it out
I had better look before and they need 18mm spacers under the 165mm speakers so they don't catch the hole diameter, could cut but don't want to deface the shelf even if I can't see it
Sorted you need 18mm spacers under the 165mm speaker then they just clear the holes
