I recently had a FRSU and ABP 30mm springs fitted. I'm currently experiencing a squeak somewhere on the rear suspension when i go over speed bumps. There was no squeaking prior to lowering the car.
The only things i can think it might be are the dampers or bushes...
Has anyone else experienced this?
Discussion Starter #2
Quick diagnosis for anyone else that reads this thread with the same issue. It has turned out to be rear exhaust silencer baffle plate, it has corroded and popped away from the bolts holding it in... Causing the rattle.
Well done getting to the bottom of it.
Some coincidence that the silencer failed.
