1 - 13 of 13 Posts
Geek :)
How much do you reckon it would cost to replace the rear windscreen on a 5 door civic??
The reason I ask is I bought an 08 2.2 Ex from Sandicliffe Ford in Nottingham about 3 weeks ago and found the rear demister didn't work. Thankfully after a quick phone call from my Dad and they agreed to diag it. So I've got to go back next week and have it fitted.
The trim on the rhs in the boot is loose. Do you think that could have anything to do with it & that someone has had it diaged by Honda found the fault and decided to trade the car in instead of have it fixed????
Are your heated door mirrors working....
Only asking cos it might be loose wire behind switch on dash
Also check your fuses
Well going off the lings pricing.
£150.67 for the window
£37.38 for an upperseal(think it should be replaced)
£74.74 for a lower seal(think it should be replaced)
£22.32 for rubber set(possibly)
£8.78 for an I-VTEC sticker
Approx £293.89 for parts but i am sure i missed a few things.
Then their is the labor.
replace rear windscreen
hi mate did you managed to replace the rear windscreen without removing the rear perspex part cause it is sealed under it. thanks hope you could help me :)
1 - 13 of 13 Posts
