181 - 190 of 190 Posts
Discussion Starter #181
Had a thorough wash today including decontamination with TAC System cloth, plastic trim treated with carbon collective coating and bodywork with BH cleaser polish and AG UHD.
Would have to apply one more time this year and it should enough to get me through the winter.
314478
314479
314480
Also after long journey on different kind of roads it make sense to do wheel balancing and alignment.
314481
Discussion Starter #182
Managed to get RRC throttle body. Will be slowly starting to gather all the parts needed for more N/A power, but still stay civilized as it's my daily. Plans are RRC intake, maybe fd2 cams if good deal pops up, fd2 pump conversion, Tegiwa exhaust manifold and Fujitsubo Power Getter.
314578
314579
Discussion Starter #183
Some time ago I started to notice that after every wash I have some water trapped in my spoiler. After seeing some examples how member tackled this issue I decided to follow and made two holes on each side on the lowest point of the spoiler.
314648
314649
Some good amount of water was trapped inside the spoiler.
314650
Also decided to run some fresh weather seal around the spoiler and fitting holes on the boot to help push water away.
314652
314651
Tested with running some water through the hose. All good and boot is dry as well. :) (y)
only just run in then.
my 2011 is only on 54k
Discussion Starter #189
Managed to get HKS RSK for a good price for my future build. Main pipe was wrapped in gold heat wrap, but not very neatly.
314981
I couldn't leave it as it is, plus underneath that wrap and glue residue I've found usual aluminium oxidation which has to be removed. Used 1000, 1500, 2000, 2500 and 3000 grit sandpaper finished by Autosol.
Before and after pics below.
314982
314983
Discussion Starter #190
Also happened that I was offered to choose one of the t-shirts from Tegiwa for free. Not sure how long that print is going to last, but quality is not bad at all and most importantly is has a nice slim fit and doesn't look crap. Will see after the first wash...
314984
