1 - 10 of 10 Posts
Don't know if anyone can help I've just fitted a alpine w970bt in my civic type R fn2 got everything to work but the steering buttons don't work with stereo have tried quite a few times as instructions have said and I've also disconnected the power input to connect box and that still doesn't work:(
R-398
You have the correct patch lead for your HU? Try plugging that in last. Vaguely remember there needs to be an order it's all plumbed together but can't mind the order.
Yeah have a alpine patch lead and iam sure I've done it correctly the instructions weren't great if anyone has any that would be great
Thanks Barry they seem to be the same as what I have so not sure what next really as I've carried out in that order
Is this the order you connected everything? It maybe worth disconnecting everything and then following this guide.
If it still doesn't work then check you patch lead for any loose wires. It maybe a faulty or the I correct patch lead may have been supplied by mistake. Try another patch lead from your local car audio specialist.
Hi danthemanc that is the instructions I've used bud and have also tried another patch lead and still no joy , lost count how many times I've tried and still no controls on the steering wheel. I did open my connects2 box and notice there's four little switches inside 2 are up and 2 are down is this correct
1 - 10 of 10 Posts
