1 - 9 of 9 Posts
Has anybody attempted to remove the factory radio in the 9th Civic to replace it with an aftermarket fascia and audio unit. Are there instructions anywhere? I would like to remove / re-install the unit to add a Digital radio (DAB) interface unit.
Yes search for mki9200 fitting instructions, or go into the how to section not to far down. Shows you how to remove the entire radio. Iv took it apart and the hardest part is removing the we bit of plastic above tha radio lol
Honda nut
think nat put a dvd player thing in his ? he might be able to help
I think I will end up getting a portable DAB radio and storing it in the centre console (plug into aux). I don't want to risk damaging any part of the dashboard.
It is probably very similar as the 8G. I think there is an aftermarket fascia available but if not you can use the one from models with nav but I guess it wont be cheap.
1 - 9 of 9 Posts
