Hi guys, I have a quick question.
If I was to but a CTR with the rage 19" alloys on, would replacing them with the 18" rims be a problem?
Is it just a straight swap or is there any camber adjustment or anything like that to consider?
Thanks in advance!
Bradders.
JAPFEST Event Organiser
ET55 7.5 width is the OEM offset and width of wheel. If you're going for aftermarket 18's make sure the offset isn't too aggressive or you may get a bit of rubbing on bumps
Don't want after market rims, just the standard OEM 18's as I'm not keen on the rage alloys!
Good man, straight swap in that case!
