Reset service light on an Accord 58"plate + error code meaning
Hi guys
I own a 58" Accord EX GT at 50,000 miles
The yellow service spanner light has popped up and I would like to figure out what the error is to rectify it locally without spending a fortune at the dealers
I bought it 2 months ago from a honda dealer so I doubt it is the oil change
Any suggestions for a quick fix or
A way to access a sub menu to display the error code
translate the code
And reset it?
I have searched the forum and the results seem to be civic oriented
I remember seeing those codes in the service book that came with my Civic - which doesn't have the "svrs" system. Haven't got it to hand, however a quick google and another forum says...
A Replace engine oil and oil filter
B inspection service
2 Replace dust and pollen filter, Inspect drive belt
3 Replace transmission fluid
4 Replace fuel filter, Inspect idle speed, Replace spark plugs
5 Replace engine coolant
7 Replace brake fluid
8 Replace air cleaner element
9 Inspect valve clearance
Afraid I don't know about resetting the service light itself
Hi guys
translate the code
And reset it?
You may have only bought it 2 months ago but when was the car last serviced? Clearly the car is telling you it needs a service. The code that is up is for
Most people me inclued get honda to turn the in car service system off and just go by the recomended every 12.5K or once a year service.
