Boooooooooooooooooooooom
Hi There
Ive got a standard honda civic SE and with the blue speedo and rev gauge which have also got some slight marks on them :( so need to replace them,would i be able to replace them both with type r ones? ie Type R rev gauge or do they need coding like the Audi Dash's at work or are they just Plug and Play
Many Thanks
rev counter
you will need the hds tester (honda diagnostic sysem) which will record the milage ect
and will put correct data into the new rev counter
if u just dissconect it you will have no record of any milage on the vehicle.
hope this helps
Right ok to similar to Audi then or if i do a straight swap it will show the millaege from the new rev unit?
Cockup Specialist
They sit behind a plastic perspex window.
How on earth can they be damaged :worms: ????
The actual plastic cover not the inside lol
Ah yes number 5 and also number 2
can i order these from honda
Cockup Specialist
Yes... click the link... or gordons honda is on the forum with civinfo discount ;)
