1 - 20 of 26 Posts
Finaly fitted a reverse camera, easy job, like anything else, fiddly though !!
works a treat.
Wired to the reverse light for camera power at the moment but later on will wire the camera to a constant 12v with ignition on.
Also need to remove the tailgate trim to hide a few wires as this was a trial fitting to see if the camera worked.
[Quote of preceding post removed. See HERE]
Yellow RCA lead from camera to input on headunit (routed through headlining and door seal)
Purple/white wire from headunit harness to reverse connecter on fusebox option plug
Black off camera to earth (bolt on tailgate)
Red off camera to reverse light positive wire (this i will change to live with ignition so rear camera can be viewed anytime rather than only from reverse)
Really want to do a camera on mine but don't fancy all the faffing behind the dash
Do I need to do something with the dvd for the sat Nov aswell.
Ex-Pat Geordie!
I have Honda NAVi installed on mine so unfortunately there is no jack plug so I don't think it will work with mine :frown2:
The dash bit is the easy bit. Do it. You won't regret it.
Sent from my Mi A1 using Tapatalk
Is the only guide for vehicles with factory nav in the wiki that's down atm
Just to add mines the nav at the top of the dash not like the one pictured
Or can some one link me to a guide
I'm off for a few days soon so I'll be doing this
Mine is a factory sat nav. Cable from eBay or there are some guys on civinfo, plug cable into back of sat nav and route the cables. No need to drill. Pm me if you want more detail. It is still fresh as I only just did it.
1 - 20 of 26 Posts
