Hi
I'm looking for advice on how to fix a section of the rubber strip at the top of my windscreen that is lifting up by about 5 mm. Does anyone have any ideas? Is this likely to lead to water leaking in?
It's a known fault with some of the current Civics.
Although your car is a 56 plate, have your Dealership replace it and try them with :-
"You and other Honda Dealers have had to replace this strip on a number of cars, so how about mine".
You dont want water causing rust under it.
My 56 had exactly the same problem recently so I just super glued it... Seems to be fine now..
I have considered superglue but I'm a bit concerned that if the part ever had to be removed, it would take big chunk of my paintwork with it!
