1 - 10 of 10 Posts
Anyone had problems with rust? Just washed my car properly for the first time in a long while and noticed I have rust right at the bottom of my passenger side door!!!
Gutted does not describe how I feel.
Surely it's covered under warranty? Does anyone know?
Unbelieveable Vteccers
I have had several problems with rust, tops of the door under the rubber seal and the roof where the rubber a the top of the windscreen has rubbed off the paint. Take it to the dealers should be covered by the bodywork warrant which is 10 years if im not mistaken.
LOUD NOISES!!!
+1
get it straight to the dealers matey
Yep, A Trot to the Dealers is required.
You don't mention the year of your car, but did you take the weep hole bungs out ?.
I hope I'm wrong, but I believe the warranty covers rust that occurs from the inside to the outer, not rust which begins on the outside.
its a 2007, so I hope it's still covered. Not sure about the weep holes, will check them tonight. Thanks for the help fellas.
Bit surprised to see rust, and other people having this issue on such a new car though!
Will update with progress and let you know how it goes
Any update?
1 - 10 of 10 Posts
