1 - 11 of 11 Posts
Hello all,
I changed my side window frame rubber seal today(where the power window slides up to), and I found out that the panel inside was rusting. The panel is at the side mirror area.
I wonder if anyone encounter that? The guy told me its normal for every car as rain water will seep through plus that panel is not painted.
Experts pls advise.
Forgot to take pictures.
Hello all,
Experts pls advise.
Yes, thats a common issue on the 8th gen civic. I'd have it looked at at your dealer. I think there's 12 year rust garantuee.
I sprayed the inside and the inner bottom of my doors with hammerite waxoyl.
Job done forget about it!
I guess you know the answer to that question already.
It could just be some surface rust, can you just wipe it off with your finger? If thats the case just give it a good clean and put on some protective coat.
Or it could be a corrosion of the panel in which case it is more severe and i think it should be adressed.
The corrosion warranty is (I think) either 7 or 12 years, according to Country
But, only for 'through' corrosion - not just surface
Just treat it with "D-Rust" or similar, then fit rain reflectors (Climair or Heko)
The rust is all the way inside the door. Cannot be cleaned entirely.
I believe all of the FN have thie issue..... Sighs
1 - 11 of 11 Posts
