1 - 9 of 9 Posts
hi m8 i have the d900 workes great no problems :D
Hi there, I've got the Samsung E900 and that works a treat, so I'm thinking that your D900 should work too!
only thing to note is that once you have paired it the first time, on the phone you need to set the pairing to 'automatically authenticate' - or it will ask you if you want to pair each time you turn the car on :D
Only takes 10 seconds, and only need to do it once :)
more info in the Wiki :wink:
1.5 Sport Plus CVT
I cant get my d900 to pair at all, it says to set the mobile to discovery mode, i assume that means turn the phones bluetooth on???
any help would be appreciated
Turn bluetooth on ready then when you're asked to set phone to discovery mode, use the phone's bluetooth menu and search for devices. This should find Honda HFT which you then select connect to.
thats it..... bingo ive been tango helped
cheers
Bet you're back on here anyway by the end of the week swearing and cursing about the HFT because believe me it has a mind of its own.
You will find that when it doesn't do what you ask of it, you start swearing directly at it. It will drive you mad!!
(Might be something to do with local dialects - so good luck!!) LOL :D
1 - 9 of 9 Posts
