1 - 9 of 9 Posts
I have a 2006 EX and the sat nav has recently been playing up. (Coincidentally this started when I got a tow bar fitted.) It sometimes fails to track me, and because it can't locate me, it can't plan a route properly. When I drive along, it seems to not be able to find a Gps signal. then, it sorts itself out again and it's ok for a few weeks. Any advice?
...............Daedalus
Might be worth checking to see if you're being tracked by enough satellites when this happens.
Hold down 'Back', 'Menu' and 'Map' simultaneously for a few seconds until the maintanence menu pops up.
I think it's the first option in the right hand column you want.
You need to be tracked by at least 3 satellites for the gps to work.
Mmm... Thanks fellas. So far the gps got me to today's location no probs, but I'll try that and see. If there's less than 3 satellites showing, why would that be?
No real reason you should get less than 3 unless you're driving through a city or through mountains.
If you're getting none though I'd guess the GPS receiver is playing up.
shameless
the aeriel is at the rear of car so maybe towbar fitting disturbed aeriel unit/wiring
Reactions: squasher
Mugenised CR-Z GT
The gps aerial is located on the left hand side under the dashboard, have you got anything covering the dashboard or anything new in your glovebox?
Aerial: (number 7)
Reactions: squasher
Cripes, in the dash? Nope, nothing new in there... I also did get the windscreen replaced a few weeks before the tow bar fitting, but I don't think the glovebox was touched. However I'll keep it in mind, and I might get the garage to give it a once over when I get it serviced, thanks v much.
OK, not got it serviced yet, but it went AWOL again yesterday. Seems to happen in/near London only, when I get within 10 miles of Heathrow.... I checked the number of satellites it had (claimed to be) connected to - eight!!! When it happens, the whole unit is very slow to respond, like when I press the buttons, when I try to zoom in/out using the jog wheel, when I try to search for a town name...... But it's OK now, in leafy Oxfordshire.
1 - 9 of 9 Posts
