I have a type r with no sat nav and was thinking of buying the honda sat nav for it i was just wondering if all the plugs are there ready for me to just plug it in???
If you go OEM it is going to cost ya big time in money and time, I considered it :worms:, then bought a tom tom and a vent mount, easy to put in and update.
If it's the Honda 'Compact' \ SSD SatNav, then I don't believe it's much hassle to install - just a power feed and a mount on the dash (will involve some dash disassembly) ...
If it's the one that is built into the top 'binnacle' in the dash, avoid it like the plague - huge amount of work to change everything over - been discussed in here several times, but never attempted ...
Picked up the S yesterday, it's awesome, but I guess you guys knew that already!
When I test drove an '11 Si there was a shift up/down indicator beneath the Rev lights. It doesn't appear on my pre facelift (59), nor my Mum's 08 ES.
Is this a facelift addition?
Reversing camera.... £12
Video in cable... £25
Grazed knuckles from trying to feed wire through endless pieces of trim... £0
Knowing fellow members have helped you save £500 on getting the Honda OEM camera installed... PRICELESS :D
Finally I have my reversing cam fitted and the cable...
Are there separate fuses for heated mirror? Checked that heating element itself is ok, but power does not reach mirror. Passenger side mirror and rear window are heating up. All wires seems to be ok as all other functions are working.
So just went out to my car at dinner time, I left the lights on when I parked up at lunch time, battery is flat as a pancake. My car is a 2009 so should be ok to try starting with key in the ignition whilst connected to a the car Im taking a jump from? This only effected MY2006 cars didn't it?
Hi to all Civic owners,
I am running a project to manufacture a custom hvac audio display for my non satnav civic mk8(2010 Model)
I am planing to use a 2.8 Nextion HMI TFT LCD display and a microcontroller board like stm32 or arduino
İdea is simle,
1) connect the microcontroller (stm32 or...
