1 - 9 of 9 Posts
The older ones did this after you updated (3.06 to 3.23 IIRC). After answering the question a couple of times, it never did it again.
It was mentioned in the satnav thread in the supporter section ... It does it on my 3.40 the first time I looked for a new destination ... has never done it again yet.
It is if you dont want to be asked if you want to go through the tunnel or by ferry when your in the UK, traveling somewhere else in the UK.
Me & Pottsy knew what the issue was from his query ... easier I suppose to understand if youve seen the issue first hand.
I don't understand the original question, is this a problem?
As Pottsy said this was a little bugette when upgrading to v 3.23
When I plotted my first route from London to Birmingham it asked whether I wanted to use the Ferry or Eurotunnel.
If you know the UK then I would say this was a small problem.
Second time around it didn't do it.
1 - 9 of 9 Posts
