1 - 13 of 13 Posts
Hi all. I've got a 1.8es civic and after several regasses, found out where it's been leaking. I'm getting tiny pin prick bubbles from the high pressure schrader valve. Honda don't do the valve on its own. You have to replace the whole pipe!!! My question is, are all schrader valves the same because there about £5 for 10 on eBay. Cheers
Haven't got the old one out yet but they look like the ones inside a tyre valve. You just unscrew it to let the air out.
Thanks. But my question is, are the schrader valves inside the high side all standard as I can get some from halfords
Grayfox, that's what I got told. Rather replace the valve for a fiver than whole new pipe with garage charges.
Stoney, cheers bud. Much appreciated :)
Got them pal.
The actual units are brazed onto the alu lines so won't come off . However I think the inserts can screw out and I'll give it a go later
Discussion Starter #12
Hi bud. Sorry for the late reply. Yes please. That would be brilliant. How much do ya want?
1 - 13 of 13 Posts
