I've got some on my screen which was already there when i bought the car, but have not yet tried removing them. Just assume they are permanent, I can't see them coming off...??i've tried searching as I'm sure this must have come up before !
The plastic screen over the rev counter on my Civic has some scratches on it which I find really annoying - has anyone had any luck removing them ?
thanks
Yes it will, use a plastic scratch remover for fish tanks. I've already done this and got great results, it'll take a bit of elbow grease but well worth it.I just wondered whether or not a light polish might work ?
cool - where did you get it from ? ANd this is definitely for the plastic screen covering the rev counter ?Yes it will, use a plastic scratch remover for fish tanks. I've already done this and got great results, it'll take a bit of elbow grease but well worth it.
well the anti reflective coating doesn't work very well !Be VERY careful using it, as this clear plastic section has an anti reflective coating applied to the external face.
A knat landing on it and passing wind, will scratch it.
Yes for the plastic covering the rev counter. Search eBay for 'Biorb scratch remover' this is the one I used, best £2.95 I spent. Try not to use it on the button surround though as the colour will start to come off.cool - where did you get it from ? ANd this is definitely for the plastic screen covering the rev counter ?
Very true, if it's scratched a lot like mine was just remove the anti glare coating altogether. The angle of the dash screen is such that I've had no problems with reflection after the coating was removed.well the anti reflective coating doesn't work very well !
I think I remember seeing the before and aftermath of that. It came out amazingly well.Very true, if it's scratched a lot like mine was just remove the anti glare coating altogether. The angle of the dash screen is such that I've had no problems with reflection after the coating was removed.
