Foglight Covers FORSALE
This happend before when i inserted the europe disc, but it went back to normal when i put the western europe disc back in. But this time i cannot get it to go. the only way to remove it it is to hold the 3 buttons down to get into the facory menu, press return then it goes to the normal satnav screen. Press ok and all is fine until i turn off then back to square 1.
Try this mate..
1. When a navigation control unit is powered up for
the first time at the factory, the "factory diagnosis"
screen (In Line Diag) appears. Normally the factory
does the steps necessary to verify proper operation
and terminate the "factory diagnostic." Until the
proper confirmation sequence is done, the screen
appears every time the vehicle is started.
2. Follow these steps to prevent the screen from
showing up in the future:
Hold down the buttons (Menu+Map/Guidef
Cancel) for about 5 seconds (the "Select
Diagnosis Items" screen will appear).
Hold down the Map/Guide button for 5-
10 seconds (A screen with a "Complete" button,
will appear).
Touch "Complete," and then the "Return" button
(the system may re-boot).
Restart the vehicle, and confirm normal
operation
Does not work for +09 models but looking at your pic, you have the old hardware.
If this does not work, then it's a trip to the stealer
Spot on:) must have the engine running and it works perfect. Cheers.
The reason I changed discs was a backup not Working very good. I've gone back to my v3.22 original disc and it now displays the traffic flow line in pink, which it never done before. Very strange as I had to install the older firmware on the disc to get it to work.
Anyway all sorted.
The reason I changed discs was a backup not Working very good. I've gone back to my v3.22 original disc and it now displays the traffic flow line in pink, which it never done before. Very strange as I had to install the older firmware on the disc to get it to work. Anyway all sorted.
If you haven't already, get a [windstar] 3.60 ...
