Mine was stuck i had to use a good screw driver i "borrowed" from work and i used alot of pressure and started to turn it slowly, but the time it i got it high enough to remove with pliers by grabbing the head when i got it off the head is
The stripped screw is on the bottom it is so bad that the black coating is fully gone, the other keys screw that is good is on the top
