I'm wanting to fit a dab arial antenna.. it's ideal for it to fit to the side pillar but there's a dam air bag there.. is there anyway I can remove the side pillar safely ??
Sent from my FIG-LX1 using Tapatalk
What's the form factor of the antenna?
There might be an alternative place for it.
If you disconnect the battery and work carefully you shouldn't have any issues, but you'd probably need to run the antenna behind the airbag, so it doesn't cheesewire you in the event of an airbag deployment
Sorted it now went on the top part of the window screen then ran the cable down the back side of the pillar same with the mic on the driver side roof just need to working out how to bring contacts and calls up on the head unit pioneer pioneer avh-x3500dab
