The Side mirrors demister not working. Is there a fuse for this or is this a common problem? It seems to stopped working one side then the other but not at the same time...
Discussion Starter #2
Did anyone get the same problem? The heated mirrors defogger is not working for the mirrors but works fine for the rear windscreen.
There's another thread on this in use at the moment, tells what fuse to check.
Mine have both failed, but small parts still demist so seems the element in the glass itself is at fault in my case.
I guess the mirror needs to be replaced to sort, guess I will live with it.
Ive got the same problem.Passenger side demists faster and a larger area than the drivers side. Drivers side clears eventually but very slow and a marked difference from passenger side.
