1 - 20 of 26 Posts
Hi all,
Do any of you find there is a split second of hesitation when you press the fun pedal!? I find that unless the revs are up high, whenever I press the accelerator, there is a slight hesitation. It just takes a split second for the power to kick in. This only really happen when I have taken my foot off the accelerator. Is anybody elses car the same?
I always blamed the intake setup. It's taking air from the wing then down into the resonator box and then upto the air box.
I have put a scoop in behind the front bumper that goes straight to the air box and I don't have any problems now
Mine was pretty bad for this , with the HKS RSK fitted. I have switched to using 99ron super unleaded and it's smoothed it out loads.
Worth a try for a couple of tankfulls just to see if it helps.
using super unleaded and a better panel filter will help slightly....hks panel filter is only £35, worth a try.
Iv always used super unleaded so maybe another reason why I haven't really noticed it.
Your saying a better panel filter yet you mention an hks which is not a better filter. It has been tested and the oem filter is actually a very good filter and very few on the market are better. That's why I stuck to oem
I found this to be the same for me too Ross.
Because the air can take a more direct route into your airbox, instead of the daft setup Honda came up with, you can now get the power that little bit earlier with no hesitation.
I used 99RON before I did this mod and there was still some hesitation. Once you do this mod and get a flashpro and custom map you'll be laughing mate ;)
Have you got a custom map with yours?
Did everything run safely before you got the map?
depends in which way you mean "better"...the hks one gives better throttle response as it breathes a bit better than oem...you just have to be careful with hks filters as they need changing regularly.
Fair enough. The oem is a good filter though so there is really no need to change. I also believe there is a placebo effect with a panel filter as many members commented on filters making a difference and then it was proved the oem filter was better
I ran a K&N with Flashpro map only for a while before I had tegi airbox fitted. I took out the panel to sell it and put back the OEM one. It made the car feel a little sluggish and sounded a bit weak in vetch.
I've always thought the same about 'Super' varients of fuel too, never really been able to tell the difference.
Didn't stop me buying a K&N Panel for the ST though :facepalm:
I think K&N are one of the few that are a better filter.
Super unleaded for me does make the car run smoother. On a standard car I don't think it gives any gains but I have noticed that it is definitely smoother especially when cold
+1
Dont see how octane rating will have any affect on this.
Not the old hesitation from the DBW throttle by any chance?
it could be partly to blame but i noticed a definite improvement switching to 99ron.
i might fill up with a couple of tanks of 95 to see if it returns and it wasn't just coincidence.
1 - 20 of 26 Posts
