Discussion thread for the Wiki page Slipping clutch. Please use this thread only for discussing what should or should not appear in the Wiki article. If you would like to add a comment, click the Post Reply button.
Discussion Starter #2
Not sure why this has popped up in my name as I didn't write it!
Hi!
I'd like to ask if I can get some references or sources to this technical bulletin the wiki is referring to
Slipping clutch - Civinfo Wiki
I have the strong feeling, that after lots and lots and lots of discussions with my dealer about this slipping clutch, that I need some proof that this problem is indeed known by Honda. They still say that they don't know about such a problem at all and I feel they don't want to ask Honda about that either...
Thank you all for your valuable help here!
Ron248
Clutch started slipping at 49,000 miles, dealer advised no help from Honda as out of warranty. Suggested continued use (not too much acceleration), but if it gets more frequent, then will need new clutch before problem possibly causes flywheel to ''burn out''!
Have never ''ridden'' clutch etc, so believe manufacturing fault is cause.
