Are they rubbing?
How hot were your wheels?
Def not seized they are free and moving and were well greased when I put them back together. They don't smell as such. Not been funny but could there really have been much I could have done wrong when changing the pads discs for this to happen?seezed calipers? try taking them apart and gresing all the moving parts.
It's not that they smell. It smoke/steam it's possible it's the disc steaming. I didn't know that there was a differen procedure for different pads. I just changed them as I normally would. Is that what you meant? I think I might go for another spin in the morning on way to work heat them up again and see what happens.if its the first time they have received heat/abuse im sure its possible.
New brakes usually do stink, especially DS2500s where you have to abuse them from the off to bed them in v quickly.
Did you follow the correct procedure for the chosen pad
I see what you mean. Have just been taking it east to bed them is as if they were oem. I cleaned one side more that the other and they side I did t clean so well seems to be the one smoking. I'm sure it will be fine just need some re assurance / confirmation from others who may have experienced thisdid you clean the disc down with brake cleaner before you fitted.
Some pads you take easy for say 100miles and slowly build up speed/ pressure to bed them in, others like the ds2500s you bed in hard, multiple hard stops until they fade and smoke, let them cool and thats them sorted,
It's best to read the manufacturers data for each pad,
give them time mate, they should be ok
That's what I think almost like a bit of burning oil of an engine if there was a spillage I suppose if the was to describe what I'm getting. Can't see it been much other that the discs pads bedding in - but thought best to check with those in the knowMany new brake discs have a thin film of oil/lubricant on the surface to prevent them from rusting, and keep them nice and pretty before you put them on the car.
Most likely you didn't remove all of it when washing them... no biggie.
