1 - 9 of 9 Posts
Changing my brakes over today, all was going well until I snapped the lower 12mm caliper bolt!!!! :mad: the remainder of which is lodged in the piston type section and as the bolt is stainless steel I can't drill it out!
Can you get just a new piston section for the caliper carrier? Is it a Honda job?
grease monkey
they are called a slider buddy, there are about a tenner new from honda buddy, need to tell them which one top or bottom as they are differnet. hope this helps
Discussion Starter · #7 ·
I know Rob I know! :)
It was going fine till I put the calipers back on and the bottom slider bolt sheered half way! :mad:
Managed to get a new slider bolt housing from the scrappy though so hopefully it'll fit!
Stud extractor probably wont work as you need to drill a hole first.
When this happens at work on machinery I weld a nut onto it.
But I 'm guessing you cant really do that in this case.
1 - 9 of 9 Posts
