1 - 14 of 14 Posts
i am thinking of getting one of these phones but before i do can people with the SE W810i confirm that they now work with the HFT with the download from SE.
i did a search but could not find a YES it does or NO it don't.
Hey,
I dont knwo if you have figured this out or not. But i work for Orange and can tell you that the W810i doesn't work with the Honda handsfree.
Hope that helps.
Oli
Oh right, its just that i was selling the said phone to a guy and the whole reason was to work with the Honda Car Kit, from memory we manged to pair it but everytime we tried to make a call it transferred the audio to the phone again.
Just thought it may be some usefull info in your circumstance, maybe honda have tweaked the HFT
looks like they have updated the list at honda.
anybody know how to get the software version off a phone as it says it will not work with a certain version
W810i Not approved for software version R4CE012
The last update occurred on 2007-02-23
Here you go Mark,
Move 4 way navi pad right, Press the * (star key) once, Move 4 way navi pad left twice, Press *, Move 4 way navi pad left, press *,
This will take you to the "Service" menu. Select "Service info"
NB The phone will go through what ever menu's and shortcuts are associated with joystick movements but just ignore them and carry on!
This should do the trick.
Oli
Hey,
Hope that helps.
Oli
Hi Chorley,
Being an Orange guy I was wondering if you could maybe advise me on a problem I have in not being able to transfer the sound from my SE K750i to my car HFT. Incoming calls work fine but I've ran out of ideas in transferring the sound for outgoing call. One guy suggested that I should change my firmware from R1CA021 TO R1DB001 but I'm not sure if it will invalidate my warranty or work with my PAYG Orange SIM. Can you advise.
Copter Doctor EX 2.2 i-CTDI Vivid Blue, Nearly Hands Free!
Hi Chorley,
[snip]
I had the same problem with my Orange K750i.
It worked fine when I first had the car/phone combi and then I used SEUS to update my 'phone as recommended via the SE website. Worked a treat and then I noticed that outgoing calls always transferred the sound to the phone :( Bizarrely, incoming calls worked fine (or was it the other way around ?)
There is a bug in the RICA021 bluetooth drivers which cause this. The problem is that SEUS will only update Orange branded K750i to RICA021 :mad:
After some careful investiagtion I discovered that I could quite happily update to RIDB001, using the DaVinci program. It's a free download, but it cost ~£7 to actually do the update. Just follow the instructions carefully.
A word of warning though, I managed to totally de-brand my phone and lost all my settings (and phone book, which I had saved elsewhere). I think that I didn't need to do that, I just ticked one box too many.
Anyway, the good news is that the phone (which now looks like a standard SE K750i) is now working fine with the HFT :D
I cannot comment on the warrenty question though, but then my phone is over a year old now anyway.
HTH
AJ
Hey Copter,
I wouldn't have thought it will invalidate your warranty, as that is with the Manufacturer and your only using SE software, might be work giving SE a ring to ask about the ins and outs.
Oli
Can anyone reccomend a phone that does work properly with the Honda HFT ?
Ive just ordered a Nokia N73 as Hondas website says it's compatible , I hope it works better than my 6680.
Jimbo
1 - 14 of 14 Posts
