Could be a number of things but the discs would be the first place to look and see if they are warped. then it could be steering like Track Rod End, drop link or wheel bearing at that milage.
Just had rear discs and pads fitted in March. Fronts I don’t think have been on that long but will check. Handbrake is being weird lately though. It’s odd. Like the handle jumps after I’ve applied it. Makes me jump sometimes. I’m hoping not track rod end. Had that on ther cars and it’s costly. Will get ABP to check everything on 26th. Thanks everyone
So randomly while reserving off my drive today the car stalled. I’ve not stalled a car in at least 10 years? Then after shopping today got back to the car to reverse again and my clutch was odd. Like easier to get to biting point or less effort to press if that makes sense. Something I need to look into or just my car having an off day?
There are two reservoirs to the top left of the engine bay, the larger is the brake fluid reservoir and the smaller is the clutch fluid reservoir. The fluid ideally should be just up to the max.
One of my wheel nuts won’t tighten up or come undone , just spins round . I’m guessing it’s crossed threaded but how can you get the bloody thing off ? At the moment obviously have 4 tight nuts and one which may be maybe not . Any ideas ?
00002 NICK-00002-ENGLAND
00003 willb1983
00006 Dyurik Nikolay Russia
00012 psychocrackpot South Africa
00013 Mirzak20 Bosnia and Herzegovina
00023 St081
00039 Stevenmcc
00053 stuvic South Africa
00064 ric type r
00067 Tom31
00068 jay1109 + jag934
00071 Robert Burns
00073 jdmfn2...
hi all
brand new to type r ownership and so far so good, I do however need need both front bottom ball joints and looking around I notice that there are two types of arm,a cast one piece item and a pressed steel item with separate ball joints. the pressed steel ones are cheaper and have the...
Anyone heard of or installed this throttle body on their FN2.
I cant seem to find any information on the internet about anyone installing it on their FN2
The price is almost 50% less than J37, and also there is 12% discount for it on tegiwa today...
I have RRC ported to 70mm...
Hi
Anyone got the guide / specs for adjusting valve clearances for UK model 2007 FN2?
Honda workshop images?
Ive seen the 'fn2workshop.co.uk' webpage, it dont work properly, i see all the little yellow folder category but when i click on any folder nothing happens....
Thx
