How much are the spacers for one axle
I've got the ones for the rear now need front do you do 20m?
Thanks mate going to ring them tomorrow to buy
Someone said put 20s on the rear and the15s on front will have to ask them tomorrow if they sell 20s
I keep ini stock, 10mm, 15mm and 20mm spacers. However the only 'bolt on' type are the 15mm hubcentric ones. These are like the kit you already have which come with studs built in to the spacer.
The 20mm spacers are also hubcentric but come as plain spacers which you replace your standard studs with longer ones supplied in the kit. This involves removing your original studs and knocking in the new, longer ones. They're more involved to fit but do 'future proof' you if you decide to go aftermarket with your wheels. Obviously your 15mm 'bolt on' spacers need the inlays on the back of the allys to fit, and so can only be used with original wheels. The spacers with longer studs don't need the inlays, and can be used with any wheel.
Hope this helps, if you need to call or want to order 01270 567177 ;)
Rich
