I don't know about stud length but they are non hubcentric meaning the weight of the car will be resting on the studs and not on the central spigot and is not an ideal situation.
Best to talk to [email protected] grinspeed or ABP motorsport ( maybe TDI im unsure) and ask about 15mm hubcentric spacers that retain the spigot. there are a few different types, one that needs longer studs and one that bolts to the hub then you bolt your wheel to the spacer but the rear of your wheels need notches so the extra nuts can fit inside.
What wheels do you run and are they notched do you know, best doing this right mate :)
Discussion Starter · #3 ·
Right ok, great, thanks for the info. Im running standard type s wheels, not sure if they are notched or not :s
