Enjoying life
Trying to locate the reason for my car being about 10% down on power so I took the plugs out. They are fairly white which indicates the engine running too hot or too lean. Is it worth me changing to a different heat range?
Anything else I could investigate if it's running too hot?
Does your car output fuel trims via the obd port?
You may have a slight vacuum leak somewhere in the inlet, hoses?
Is your fuel system operating okay?
Perform an injector flow test?
Enjoying life
I'm going to have to Google some of that Farqs :D
Funnily enough the hose that runs from the iacv to the inlet manifold was a little easy to remove. I put a small hose clip on it, did an ECU relearn and put a velocity stack on, the car really pulled well this morning. The car could have been running lean prior to my remap, that's something I should consider. Might look up the injector test, mine sound noisy.
Hehe, fuel trims and logging can be a useful diagnostic tool to narrow down likely causes.
A vacuum leak is probably the most likely, are the injector seals okay?
Then injector flow and leak back tests would be helpful.
