1 - 10 of 10 Posts
At first, sorry for my english. I'm from Germany near Hannover.
I will try to describe you how I've installed my new speakers in my Type S.
Later I will add the installation of the subwoofer and amplifier in the boot cause the salesman haven't send the package with the sub & amp at the time.
Front system: Hertz Dieci DSK 165 2-way compo
Rear system: Hertz Dieci DCX 165 2-way coax
Subwoofer: Powerbass S-10
2-channel amplifier: µ-dimension 2075
High/Low Adapter: Helix AAC Active Controlled High-Low Converter
Aditionally I've installed 10 plates of bitumen (1,25m²). 8 pieces in the doors (1m²) and 2 in the rear (0,25m²).
furthermore I've needed:
Wood plate for the boot
MDF-plates for the sub-box
fleecemat for the sub-box
Connection terminal for the sub
Foam for the door and rear covering
Speaker cable for the High/Low Adapter
Many screws & nuts
Isolation tubes for the cables (to avoid rattling)
blade terminals/couplers
Heat shrink tube
MDF-adapters for the speaker chassis
paint/varnish to seal the MDF-adapters
Silicon bond for sealing the adapters
Needed tools:
Router
Drill
Hot air dryer
Electric tools...
Now to the pictures:
First impressions of the boot plate und sub case:
bars under the boot plate for better fitting:
The tweeter:
...from the back bonded with silicon adhesive:
The door covering additionally insulated with some foam (to avoid rattling):
The insulation of the door and the installation of the speaker adapters.
The adapters for the rear speakers
Insualtion and installation of the rear speakers:
This was the task for about 3 days ;)
The next pictures will follow when the absence components (sub/cables/amplifier...) arrive...
Greets, Andre
You're or your..........
that looks scary
good work [smilie=ebil-thumbu:
look forward to the next pics
and welcome to the forum ;)
Thanks guys and be curious about the further installation. I think the package will arrive on time till weekend [smilie=cheeky-grin:
Those rear speaker adaptors are beautiful. My mission for this weekend is to make some the same.
Good luck ;)
Good luck ;)
Thanks! Actually, I am looking closer and there is something I don't understand about the speaker adaptors..
The larger outer ring, the circle one.. why is it there? I had in my mind that the inner one, the one that fits to the Honda mounting holes, was smaller than the speaker and that the speaker screwed into the outside ring, but I can see that's not the case.
In the first picture, the inside ring is wider and the outside ring looks thin:
but in the next picture the inside looks thinner and the outside looks wider:
Can you help? :)
thanks
1 - 10 of 10 Posts
