So I've read on other forum posts the most likely cause of my Speedo currently reading 0 mph at all times is due to a gearbox speed sensor error.
This past weekend I was tinkering with my clutch and while I did not remove the sensor I loosened it and turned it to access a bolt. Shock I forgot to put the washer back on. I have now put it back. Also didn't help that I forgot to reconnect the connector ?
Just wondering if I'll have to clear the engine fault codes for it to reset itself or if I'll need to complete some further investigation? Because it's still reading 0 mph.
The gearbox sensor is delicate,
When my gearbox blew and I had it changed I forgot to add the correct washer on and I was getting the 0MPH on my dash untill I put this back on.
I didnt need to code reset it just worked.
I would check the sensor and the connection and have you put the correct sensor on and not over tightened it
