1 - 20 of 102 Posts
Hi
I am thinking about swapping my HKS RSK for Mugen, I understand I will go back to the oem intake plastic pipe.
I am also thinking about getting the RRC manifold.
The spoon TB is 70mm and is a decent price.
Will it match the RRC manifold and the oem intake pipe?
I guess the RRC can be bored out but the intake pipe Might be a problem? Also i heard modifying it can cause it to split over time.
No reply, he mentioned the fd2/mugen and i asked was there any point in going larger again toda/spoon etc and what were the gains and such as they are dearer items again.
My original choice was the skunk2
im also thinking this to, but over heard someone saying bigger aint always better...... hope paul or someone can explain a bit better?
+1
Yes, it will fit.
By the way, you could buy the Samco induction kit:
This will improve the intake as it's inside is smoother so the air will flow laminar and less turbulent.
thanks, who sell this?
Thanks gass :)
Mugenised C/W
Yes, it will fit.
YouTube - Mugen High Performance Intake Kit Installation
Don't waste your money on this. I had one fitted but sold it as it collapses under load.
Even if it did not collapse it is too small for a bigger throttle body.It will fit but has to be stretched.
Discussion Starter #12
Thanks for letting me know! So what shall I use? oem pipe? Im torn between toda TB and spoon TB
Mugenised C/W
Personally for the cost I would not bother.I watched my car being run with a FD2/Mugen throttle body then again with the standard tb-no difference!
Might work if you can find an inlarged intake pipe, but I reckon it would be one of the last performance parts to fit,after wilder cams, higher comp pistons etc.
Discussion Starter #14
The HKS intake pipe is enlarged isnt it? I thought the Mugen TB wasnt that much different to stock?
The TODA TB claims 7bhp increase, thats one mighty claim!
I will be doing RRC and intake at same time so thought id get TB done now whilst im in that area. plus save money on remaps.
Whilst Ive got your attention, to fit the RRC does the slam panel need to be modified? Also will the RRC need extra supporting brackets?
i have rrc and spoon tb. 100% fit. but bigger tb gives almost 0 gains.
if you fit a bigger tb get a hair dryer and put hot hair on the intake pipe for 1 or 2 minutes. It will strech and will fit the bigger tb. If you try to put the intake pipe on without this it will be very difficult to fit.
The 7hp claim is on their toda stroker kitted FD2 (2150cc), which probably has cams, exhaust etc... so a pretty poor way to claim gains for a throttle body. Better to spend your money elsewhere.
Discussion Starter #17
What TB gives good gains then? If any?
Aye Aye....
I've got the RRC Ash, seems to give a decent gain no modification required to fit it, can't comment in the bigger TB though sorry, although you don't need a remap after it btw, just a 'tweak' to the map
Mugenised C/W
No mods needed to slam panel I just moved bonnet release cable slightly.It looks very close but with the number of engine mounts the motor hardly moves.
The standard FN2 brackets do not fit the RRC I suppose you could buy the Fd brackets but I along with others have not.
If you do go for the RRC do not forget the Hondata thermal intake gasket.
Discussion Starter #20
Ok thanks, Ill probably get some support brackets then to be on the safe side.
Yeah Im going to get the therml gasket.
So what TB you got?
1 - 20 of 102 Posts
